Quad ESL-63
Username: Ranweiss
Hi,
I was wondering, which amplifier would do justice to the Quad ESL-63? I currently use the Quad II tube monoblock, but these are just on load from my bedroom's ESL-57...
Many thanks for your support!
Ran
Username: Project6
Post Number: 9293
Why not get another Quad monoblock?
Username: John_a
LondonU.K.
Post Number: 4481
The recommended rating is 50 to 100 W per channel. I currently use a PrimaLuna Prologue Two which is an integrated stereo tube/valve amp, rated at 40 W per channel. It works well. I find the 4 Ohm output taps are better; the speakers tended to go into overload protection sometimes with the 8 Ohm taps. I also used a Sony TA-N55ES solid state for a while, with good results.
If you can afford the new Quad tube monoblock system it would be a natural choice. Also McIntosh.
Congratulations on owning two legendary speakers. List them in your profile! Much better than Bose.
See thread New Quad ESL models and links therein.
Username: Nuck
Post Number: 3762
As John prompted, please update your profile, Ran!
It is so much easier to help and understand where you are.
Here is hoping you enjoy the forum, it is a bit off the beaten track at times, but quite a ride.
Welcome!
Username: Ranweiss
Post Number: 7
I'd admit, that using valve amp is a bit scary for me, that the tubes got limited life span and I'd rather not forget to turn it OFF before going to bed. Therefore I wanted to find a good enough amp for the ESL-63.
Ran
Username: John_a
LondonU.K.
Post Number: 4483
Ran,
There are many suitable amplifiers. You could try asking on the "Amplifiers" topic. Peter Walker of Quad thought tube vs. solid state was not an issue. ESL-63 Pro...? Great. Especially for U.S., I read.
