New member Username: Jerkstore43Post Number: 1 Registered: Aug-06 | Making my first receiver purchase. Just got my media center PC yesterday. Plan on using Paradigm CT 90 speaker setup and eventually buying the 60" SXRD HDTV from Sony (just have a good old 36" tube right now.). I've been looking at the HK AVR 635 and 645. 645 has (or will have when released...)HDMI switching, but the 635 is half the price! Any guidance would be greatly appreciated. Thanks. |
New member Username: Jerkstore43Post Number: 2 Registered: Aug-06 | Here are links just in case: 635: http://www.harmankardon.com/product_detail.aspx?Region=USA&Country=US&Language=E NG&cat=REC&prod=AVR%20635&sType=C 645: http://www.harmankardon.com/product_detail.aspx?Region=USA&Country=US&Language=E NG&cat=REC&prod=AVR%20645&sType=C Thanks! |
Silver Member Username: GamerdudeOntario Canada Post Number: 106 Registered: Apr-06 | THe real question is what about your sound card? you most likely have a realtek AC97 on board sound witch is desent but not the greatest adn if your gonna use this computer for your media i dont think u would wanna use it try getting something from creative for a sound card the sound is more robust with a desent card |
New member Username: Jerkstore43Post Number: 3 Registered: Aug-06 | I've got high def 7.1 onboard audio on an ASUS A8N-SLI Premium NFORCE4 motherboard. It states this in the ASUS specification: Realtek ALC850, 8-ch High-Definition Audio CODEC Jack Sensing and Enumeration S/PDIF out interface What do you think? |
Gold Member Username: NuckPost Number: 3731 Registered: Dec-04 | Well see, right there! It says it has Sensing and Enumeration worth Jack! |
Gold Member Username: KanoBC Canada Post Number: 1055 Registered: Oct-04 | Check out the Chaintech AVR710 sound card, I was really impressed with the quality through optical for less than $30. |
