NAD Amp 304 Power Problem
Username: Hehehaha
The power of the amplifier does not turn green after the red light. It cannot work. Does anybody knows how to resolve it?
Username: Nickclev
Hi Edwin
Saw your post here about the red light on your amp. I have a similar situation on my NAD amp and it switches off and light turns red. What was the problem and was it easily fixed
Thanks
Nick
Username: Nuck
Post Number: 4730
With the speaker leads removed, is the result the same? Exactly?
Username: Nuck
Post Number: 4731
Addendum...in tightening the output lugs, could you have turned a base of one(or both), invoking a short shut-down?
Username: Nickclev
Hey Nuck
I took the speaker cables out as you said and guess what, amp worked okay, so I put speaker cables back in and you know what again, I did not have the shutoff. Maybe the wires were touching each other or the other input but thanks so much for your help. You look like you solved my problem.
Thanks again
Nick
Username: Nickclev
Hey Nuck
Thanks again
Nick
