AElite sound problems
Username: Scribe
Hi guys, ive recently noticed that the bass producing cones on my AElite Threes have a habbit of producing higher frequency "free wobble" sounds asif they are wobbling freely between heavey beats, however this happens at reasonably low volumes. Is this just unavoidable and its always been there or is there something wrong with my speakers?
I do hope I haven't overdriven them and would be pretty miffed as i've never turned my amp up all the way and it's only 135wpc and these speakers can take 175w each apparently.
Thanks for any help.
Username: Project6
Post Number: 9096
Where did you get these AElites?
Username: Scribe
Brand new at a local but reasonably big hi-fi store.
Username: Project6
Post Number: 9129
If it is brand new and you are not satisfied with the performance, you really should return it and get something that will perform to your expectations. I haven't really heard of this brand. Where is this local place that you purchased it from? It is not from a white van is it?
Username: Scribe
http://www.acoustic-energy.co.uk/Product_range/Aelite_series/Aelite_three.asp Are the speakers, they're not brand new, about two months old so i can't really return them.
