SUB AMP
Username: Rmanz
SI, NEW YORK USA
I AM USING VSX-81TXV PIONEER ELITE WITH JBL HOME CIN SERIES . I AM RUNNING 7 SPEAKERS OFF OF THE RECEIVER NOW AND NEED TO GET A AMP FOR THE SUB (INFO BELOW). THE ROOM IS PRE WIRED AND I WILL BE UPGRADING AS I GO ALONG ANY SUG WOULD BE GREATLY APPRECIATED.THE ROOM IS APPROX 10X10 AND I WILL MOSTLY BE WATCHING MOVIES.MY BUDGET IS APPROX $1,000.00.Subwoofer
Amplifier Power (RMS) 100 Watts
Low-Frequency Driver 8" Woofer, bass-reflex enclosure
Dimensions
(H x W x D) 15" x 13" x 14"
(381mm x 330mm x 356mm)
Username: Project6
Post Number: 9016
First suggestion...stop typing in all caps!
Now, for that budget, you should really take a look at powered subwoofers and sell the sub you currently have. That Pioneer has a subwoofer output that can connect to a powered sub, the connection is very easy. You can get rid of the JBL cinema series all together and get a nicer more detailed set with the budget you currently have and the money you get for the cinema series.
Take a look at HSU subwoofers and Ascend Acoustics.
http://www.ascendacoustics.com/
