Username: Simikang Post Number: 19 Registered: Jul-06
Friday, July 28, 2006 - 03:35 GMT hi, i have a sony mini hifi macro component system its basicly two speakers and a bass and the main part, the problem is when ever i exceed the volume passed 11 or so it shuts down it to protection mode or somthing the light strats flashing and i gota unplug it and replug it, any body know how i can fix it without sending to a shop?
Username: Project6 Post Number: 8997 Registered: Dec-03
Friday, July 28, 2006 - 12:56 GMT What speakers are you using?
Username: Simikang Post Number: 20 Registered: Jul-06
Saturday, July 29, 2006 - 01:14 GMT its the regular speaker it came with its 300 wats the mhc models
Username: Project6 Post Number: 9006 Registered: Dec-03
Saturday, July 29, 2006 - 02:55 GMT Check the wiring and see if you have them crossed. Has this been happening since you purchased the unit or is it something new?
Username: Simikang Post Number: 21 Registered: Jul-06
Saturday, July 29, 2006 - 04:23 GMT it happend about three months after i bought it
Username: Project6 Post Number: 9017 Registered: Dec-03
Saturday, July 29, 2006 - 04:42 GMT What is the warranty on the stereo? That is a defective unit, it should be repaired.
Username: Simikang Post Number: 22 Registered: Jul-06
Saturday, July 29, 2006 - 05:26 GMT il have to call up sony tomrow then, thanks
