Good cd but not a penny over $320
Username: Xxraiderxx
1, Ga Us
Post Number: 29
looking 4 a good cd player that looks good and plays better then it looks but not over $320.
thanks
Username: Pitchblack
I would go with either Alpine or Eclipse. Im acually sellin My Alpine CDA 9851 CD player.i used it for less then a month so still pretty much brand new.
Username: Twebbz
Oakland Park, Florida USA
Post Number: 432
Cambridge Audio Azur 340c
http://www.spearitsound.com/Cambridge_Audio/Cambridge_Audio_340c.asp
Username: Petergalbraith
Rimouski, Quebec Canada
Post Number: 1737
Shane, this isn't car audio!
Post Number: 9
K relax.. Then yeah go with the Cambridge 540C compact cd player. Go to www.soundenvironment.com
Username: Project6
Post Number: 9069
Shane, do you have this unit?
Post Number: 11
No i dont have it.
Username: Project6
Post Number: 9086
Oh, I see.
Username: Ftalife
Post Number: 122
Check out the features you want then search the web and auction sites. Also check the reviews.
https://www.ecoustics.com/home-audio/
Username: Project6
Post Number: 9128
Thanks man, that is such a great tip. I'm glad that you became a member and totally infused us with great knowledge.
Username: Ftalife
Post Number: 132
Thanks Bernie Glad to hlep out.
Username: Frank_abela
Berkshire UK
Post Number: 1560
How much is a NAD C521BEE? It's a good little unit.
Regards,
Frank.
Username: Uback007
Post Number: 119
I would go with a Cambridge Audio 540c v.1
hands down...get some great bang for the buck connects from www.signalcable.com - the ones that are $50 for a 1 meter set - I installed them after I got my pre-owned 540 v.1 and was blown away by the difference in sound. There's no need to spend a ton of money on cables, these babies sound every bit as good as cables that I tested with the unit that cost $500..no kidding...
check them out.
Username: Hawk
Highlands Ranch, CO USA
Post Number: 875
Raider:
I know you said no player over $320, but frankly, you can get a killer NAD 542 for just a few dollars more. DMC Electronics (dmc-electronics.com) is currently offering factory refurbished NAD C542s for $349. a Great player in its own right and a killer for that price. Just an idea . . .
Berkshire UK
Post Number: 1598
Wow, that is a great price for an excellent little player. The NAD C542 retails for nearer $500 in the UK!
Raider, if you can go the extra couple of cds-worth, that's an excellent little machine.
Regards,
Frank.
Username: My_rantz
Australia
Post Number: 759
Raider, we are most likely just practicing typing here since it's nearly a month later, but I agree with Hawk and Frank about the C542.They are $699 new here in Aus and worth every cent. Extremely happy with mine.
