Bronze Member Username: Runit3Portland, OR USA Post Number: 38 Registered: Jun-06 | I bought a 12" MA audio HK12X2 and a 2 channel boss pd-3000. I was wondering how well these would match up and how i should go about wiring them. I already made a ported box for the sub at the correct dimensions and the sub is mounted in it. here are the specs MA Audio HK12X2 sub: 1500W RMS 3000W MAX Sensitivity: 88.9dB @ 1w/1m ![]() Boss PD-3000 amp: Amplifier Type Dual Channel Bridgable Bridgable RMS Power at 4 Ohms 350 W x 2 RMS Power at 2 Ohms 700 W x 2 Performance Frequency Response 9 Hz - 50000 Hz Signal to Noise Ratio 105 dB THD at Rated RMS Power 0.01 % MOSFET Circuitry-Yes |
Bronze Member Username: Runit3Portland, OR USA Post Number: 39 Registered: Jun-06 | sorry i forgot to add that the Boss Pd-3000 amp at 1 Ohm is 1500 W x 2 |
Bronze Member Username: Runit3Portland, OR USA Post Number: 42 Registered: Jun-06 | correction its 1500 W x 2 at a HALF ohm |
Gold Member Username: Project6Post Number: 8859 Registered: Dec-03 | Wrong forum. Try car audio. |
Silver Member Username: Daniel_canadaCanada Post Number: 164 Registered: May-06 | Frequency Response 9 Hz - 50000 Hz ?????????? |
Gold Member Username: Touche6784USA Post Number: 1081 Registered: Nov-04 | its called being a dumb@ss on his part. this is the kind of stuff you get with people that dont know how to read. |
New member Username: Tman86Post Number: 5 Registered: Jul-06 | ya if only we could all b perfect like u |
Gold Member Username: Touche6784USA Post Number: 1087 Registered: Nov-04 | unfortunately you arent. now go to the car audio forum and ask you questions there. while you are at it, ask about how Magnepan speakers sound with a ADCOM amp, it will be just as relevant as your misplaced question here. |
Gold Member Username: Project6Post Number: 9171 Registered: Dec-03 | Magnepans sound excellent with ADCOMs. ![]() |
