Can't load tunes into my nano
Username: Irapeople
New York, NY
Suddenly i can't load tunes into my nano. Used to work fine. hey are m4p's from music store. Itunes is version 6.0.5. HELP!
Username: Ftalife
Post Number: 144
Try to reboot it.
http://www.apple.com/support/
Username: Ftalife
Post Number: 145
if you can't figure it out find your local ipod store.
Username: Ftalife
Post Number: 146
The apple store I mean. They will fix it for you or replace it if you are under warranty.
Username: Ftalife
Post Number: 147
If your warranty is almost up it is usually a good deal to buy the extended warranty. If the price is right.
