I have a Harmon Kardon AVR 8000 and it is driving Polk Audio RTI10s. It feels like it has absolutely no power... like on a soft mute or something. I have to put the volume almost all the way up to comfortably listen to anything. I know these speakers are not the best and my reviever is a lot nicer... but, my 15 year old pioneer with $100 Jensen speakers sounded stronger. Any advice??? Thanks.
Richard check your settings as the AVR 8000 is one of the most powerful receivers HK ever made. The RT series from Polk are decent, of course there are others out there that offer more for the same amount of money, but I think you may have your speaker polarity(wires) incorrect, this can result in weak,hollow sound,assuming the rec. doesn't go into protection when the speaker wires are wrong(most HK's do.) The RT is a moderately demanding speaker but the HK should be more than adequate for this speaker. If a setting or wiring is not to blame then there is definately a problem with the receiver as this AVR is very strong with a torridial transformer power supply that should be able to drive almost any speaker within reason with authority and rivals some decent entry model multichannel amps.
It sounds like you have some definite setup issues. Something must be connected or calibrated wrong.
You'll want to refer to your manual & double check your connections & settings, because diagnosing what you did wrong wont be easy based on the above information. It could be any number of things.
Excuse me Rush, just stating my opinion, that is allowed here or is it not?!!, You are right though it was not relevant to the thread, my apology to Richard.
