New member Username: JustzepitPost Number: 1 Registered: Jul-06 | My Itunes on my comp is totally blank because I had to get a new harddrive... but I have my songs stored onto my actual Ipod. Is there anyway that I can get them from my Ipod back onto my Itunes? Im afraid since there isnt anything on my Itunes, my Ipod will be wiped blank. |
Gold Member Username: Project6Post Number: 8786 Registered: Dec-03 | Nope...it is a oneway transfer, but if you can find a hack, you can. |
New member Username: JustzepitPost Number: 2 Registered: Jul-06 | What's a hack? |
Gold Member Username: Project6Post Number: 8794 Registered: Dec-03 | That is when you try to hack into your iPod's programming. I don't recommend it, though! |
New member Username: JustzepitPost Number: 3 Registered: Jul-06 | All right, thank you ![]() |
New member Username: JustzepitPost Number: 4 Registered: Jul-06 | So basically, when I plug my Ipod in... all of my songs will get erased? |
Gold Member Username: Project6Post Number: 8797 Registered: Dec-03 | Not if iTunes is configured to update manually. If it is set to automatic update, the songs will get erased. You don't have a back up? |
New member Username: JustzepitPost Number: 5 Registered: Jul-06 | My whole hard drive got wiped, I had to get a new one. The only time I can configue it to manual is when my Ipod is plugged in.. or is there another way? |
Gold Member Username: Project6Post Number: 8834 Registered: Dec-03 | A hack is probably the only way. Type in "iPod hacks" in a search engine and you will find a thousand sites. |
New member Username: JustzepitPost Number: 6 Registered: Jul-06 | Will it mess up my computer? |
Gold Member Username: Project6Post Number: 8838 Registered: Dec-03 | No |
Silver Member Username: FtalifePost Number: 140 Registered: Jul-06 | Wow I though that you could. |
Silver Member Username: FtalifePost Number: 141 Registered: Jul-06 | I have never tried it though. |
Silver Member Username: FtalifePost Number: 142 Registered: Jul-06 | check here. http://www.apple.com/support/ |
