Gold Member Username: Edster922Abubala, Ababala The Occupation Post Number: 4335 Registered: Mar-05 | http://www.amazon.com/gp/product/B000FUJEM0 Wonder how it would compare to a T-amp running a pair of $50 Insignia bookshelf speakers and a $60 Toshiba 3990 DVD player... |
Gold Member Username: NuckPost Number: 3432 Registered: Dec-04 | What makes it somewhat decent? |
Bronze Member Username: Eib_nationOhio EIB Nation Post Number: 28 Registered: Jul-06 | Based on his many reviews, it appears he is the expert on just about every component he's never personally owned. http://www.amazon.com/gp/cdp/member-reviews/AT6CZDCP4TRGA/ |
Gold Member Username: Edster922Abubala, Ababala The Occupation Post Number: 4338 Registered: Mar-05 | Nuck: the speakers at least have decent cabinets, and the class-D amp does have superior clarity. The problem is the ribbon tweeters in the speakers, which can be a bit fatiguing. Rush: yes, I sure am! Heh heh! And I don't give pompous, one-note advice on room treatments to every single question under the sun either, unlike some people. (cough cough) |
Bronze Member Username: Eib_nationOhio EIB Nation Post Number: 38 Registered: Jul-06 | ![]() |
Bronze Member Username: GamerdudeOntario Canada Post Number: 88 Registered: Apr-06 | http://www.bestbuy.ca/catalog/proddetail.asp?logon=&langid=EN&sku_id=0926INGFS10 073575&catid=23256 Maybe a little better? |
Gold Member Username: Edster922Abubala, Ababala The Occupation Post Number: 4354 Registered: Mar-05 | maybe...but the BB listing seems to suggest that it's a passive subwoofer, which would be a scary proposition. I also wonder if it has any bass management when a sub is added or if the mains are still run full-range. |
Bronze Member Username: GamerdudeOntario Canada Post Number: 97 Registered: Apr-06 | well iw as at my local BB and it sounded great but this one have spring clips and i dont really no about bass management it was passive tho didnt sound too bad nice clean sound pretty loud too |
Gold Member Username: Edster922Abubala, Ababala The Occupation Post Number: 4363 Registered: Mar-05 | yeah, the spring clips are a bummer indeed. Personally I'd much rather pay less for the sub-less version, and shell out $150 for an Athena p4000 or $100 for a Dayton 10". |
Bronze Member Username: GamerdudeOntario Canada Post Number: 99 Registered: Apr-06 | And use the philips amp? theres like three versions of this mini system on philips.com should check it out i got some older philips Class D amp:D i dont ue the speakers that came with it there too deep no highs Sprong clips tho lol |
New member Username: Perycles2005Post Number: 8 Registered: Mar-05 | Hi, I have a Panasonic SA-PM39D 5 DVD/CD Stereo system and when I was changing the DVD's with the remote control it got stuck (the magazine)...I try to ubjamm it but I made it worst...do anybody knows of a decent shop around in San Diego to repair it...or have any ideas...thanks in advance. |
