New member Username: Steve_jrPost Number: 5 Registered: Jul-06 | Granted I would love to have McIntosh's MCD201 CD Player paired with the MC252 but I simply can't afford that. Instead what cd player would you recommend with the McIntosh integrated amp ( MA6300)? I would like to stay around $1000 for the CD player. Thanks! -Steve |
Gold Member Username: Jan_b_vigneDallas, TX Post Number: 8851 Registered: May-04 | At $1k the current best bet to match the 6300 would be the Rega Apollo. |
Gold Member Username: ArtkAlbany, Oregon USA Post Number: 3463 Registered: Feb-05 | The Rega Apollo is a great player and so to is the Audio Refinement CD Complete Alpha. One-on-one I preferred the Audio Refinement. It has been discontinued as YBA decided to carry a budget line with the YBA name on it...meanwhile there are still some good deals to be had on it. You must buy the remote separately. http://www.spearitsound.com/Audio_Refinement/complete_series.asp#CD%20Complete |
