New member Username: Theclem54Queensland Australia Post Number: 1 Registered: Jul-06 | http://sound.westhost.com/project117.htm Can anyone afford to make one of these... it'll be at least 5 years before I can spare enough and by then I'll probably have spent all my money on more useful systems anyway... |
Silver Member Username: RavbainsMelbourneAustralia Post Number: 156 Registered: Mar-06 | No I cannot afford one of these, nor do I have any interest or indeed the skill to make such a device. I am not sure about 1.5KW, but there are plenty of very powerful amps out there if you have the money. For example: http://www.boulderamp.com/index_flash.html Take a look at the 2050 mono amp. -Rav |
Silver Member Username: Daniel_canadaCanada Post Number: 151 Registered: May-06 | 4000w in to 2 Ohm!! |
Gold Member Username: NuckPost Number: 3281 Registered: Dec-04 | This is home audio...try car audio. hehehe |
Silver Member Username: RavbainsMelbourneAustralia Post Number: 159 Registered: Mar-06 | Howdi Dan, yeah I think the big Boulder 2050, is designed to drive big speakers like the Wilson Alexandria, or the top of the line Avalons: http://www.wilsonaudio.com/products/alex/index.html But this stuff costs a bit more than the chump change that I can just about muster up...... cheers Rav |
Silver Member Username: Daniel_canadaCanada Post Number: 154 Registered: May-06 | Those speakers are just too big. 2200lbs a set! |
Gold Member Username: Frank_abelaBerkshire UK Post Number: 1517 Registered: Sep-04 | In fact the Wilsons aren't that difficult to drive. They're really rather efficient (95db/w/m, 8 ohm impedance). If you want difficult to drive have a look at Apogee Scintillas (1 ohm nominal with minimum impedance of 0.7 ohms), ATC SCM10 (84db/w/m, 4 ohm), Totem Mani-2s (85db/w/m, 4 ohm). There are loads of powerful amplifiers from the likes of Boulder, Classe, Bryston, Carver, Chord Electronics, Chapter Audio. The new Class D amps from Rotel look immensely powerful too, although low impedances will probably not do them any good. |
Silver Member Username: RavbainsMelbourneAustralia Post Number: 173 Registered: Mar-06 | Hi Frank, interesting.... Wow the Apogee really does sound like a amp killer of a load. Would probably activate the protection on 99% of modern integrated amps (not that you would want to use an integrated with such a speaker...). I have heard the Alexandria at a hifi shop in Sydney, they were being driven by a pair of Levinson mono-blocks. Very impressive, and produced a realistic sense of scale. I tried a class-D panasonic HT receiver, that a friend recommended as having a cult following. I connected it to my humble NAD speakers. I must admit that it had a much more pleasant mid-range and treble register than you had any right to expect for its price. But it had a feeble bass, my NADs are 89dB/w and 6 ohms nominal. Even my venerable old A60 did a much better job in the bass department. (Major digression: After all my mods on the A60 it is sounding awesome these days. And also looks impressive with its new "BLUE LED" power indicator. But it now has very taught fast bass (due to I think the Panasonic HA reservoir caps, and the fact that they are by-passed by 68uF non-polar caps. This is my only regret in this project, that I could not increase the size of the reservoir capacity in the A60, due to lack of space inside it's slimline case.). |
Silver Member Username: RavbainsMelbourneAustralia Post Number: 174 Registered: Mar-06 | sorry forgot to add, the bass on the A60 is now taught and fast, but it is somewhat lean.... End of digression.) |
Gold Member Username: NuckPost Number: 3358 Registered: Dec-04 | Rav, make a nice add-on box and stuff it full of big caps, call it a power supply. |
