Reviving my old amp(stereo)
Username: Mainemike
I was hoping for some speaker advice, i want to revive my old stereo(adcom gfa 555, hafler dh-101) and need some speaker advice. I was thinking about the magnapan mmg. Has anyone heard these. They are mail order which makes it perfect for me in maine, but was a little concerned about the lack of bass response. Was wondering about some sattelites in the 500 dollar range that can go with my passive sub. Its hard up here in the frozen tundra to find a stereo shop. Just looking for some suggestions. Thanks mike
Username: Nuck
Post Number: 3270
quinn the eskimo?
Username: Mainemike
yes I am an eskimo, looking for the perfect eskimo pie!
Username: Chitown
Post Number: 1144
I think your best bet is the internet only speaker dealers since you they give you a 30 day money back warranty including the shipping. I would give Aperion a look. I revived my old Rotel amp with a used Rotel CD player and a pair of their satellite speakers hooked up to an BA older passive hub. This hodge podge of (Frankenstein) of a system sounds remarkably good in my bed room.
Username: Mainemike
thanks stof.
Username: Edster922
Post Number: 4307
if looking at Internet direct, check out ascendacoustics.com --- probably the most widely acclaimed by both pros and consumers of the IDs, known for their accuracy and neutral/flat frequency response.
As for sats in the $500 range, if you're looking at 5 speakers I'd recommend the SVS sb-01s from svsubwoofers.com
