Bronze Member Username: Apresler07Canal Winchester, Ohio USA Post Number: 22 Registered: Jun-06 | I currently have a Onkyo Tx-sr303 5.1 reciever and i need a sub to complete my setup my budget is 150 This is my home theater setup as of now https://www.ecoustics.com/electronics/forum/home-theater/242252.html |
Gold Member Username: Edster922Abubala, Ababala The Occupation Post Number: 4297 Registered: Mar-05 | Athena AS-P4000, $125-140 |
Bronze Member Username: Apresler07Canal Winchester, Ohio USA Post Number: 25 Registered: Jun-06 | Is that a good sub? I was looking at the dayton audio sub from partsexpress.com it is a 12" 150watt amp for 149. I have never heard either of them so i have no way of comparing. |
Gold Member Username: Edster922Abubala, Ababala The Occupation Post Number: 4305 Registered: Mar-05 | If it's HT only that you're doing, I imagine the Dayton should give you more boom. The Athena should be faster and more accurate esp. with music. |
Bronze Member Username: Apresler07Canal Winchester, Ohio USA Post Number: 28 Registered: Jun-06 | so the dayton would be for movies and the athena for music. Which one would be the best choice for a 60% music 40% movies. I like a lot of boom but not too much that it overpowers everything else. |
Gold Member Username: Edster922Abubala, Ababala The Occupation Post Number: 4308 Registered: Mar-05 | Then stick with the Athena; if you want to be safe upgrade to the larger AS-p6000 for an extra $100. |
Bronze Member Username: MrlorenChulaJuna, CA Post Number: 22 Registered: Nov-05 | I seconded the athena. I was going to get the 12" till the wife said ok for the HSU STF2. I checked out the Athend AS-P400 at BB and it was good better than my 12" Sony and my 10" KLH which are now bedroom subs |
Bronze Member Username: Apresler07Canal Winchester, Ohio USA Post Number: 30 Registered: Jun-06 | How much is the AS-P400 at best buy |
Bronze Member Username: MrlorenChulaJuna, CA Post Number: 23 Registered: Nov-05 | when they had it, it was $199usd |
Bronze Member Username: SerniterPiscataway, New Jersey USA Post Number: 35 Registered: Mar-06 | In USA, you could get it from amazon.com for $150... http://www.amazon.com/gp/product/B0009WRUZ2 |
Gold Member Username: Project6Post Number: 8550 Registered: Dec-03 | You could also try Audio Advisor.com, they usually put Athenas on sale. |
Bronze Member Username: Eib_nationOhio EIB Nation Post Number: 20 Registered: Jul-06 | My 2 cents, Save until you can buy something decent. Dont waste your money by purchasing a cheapo $150 pile of junk. Hold off until you have scratched together, at least, $400. At least then, you can buy something respectable. Anything in the <$400 price range isnt worth owning. Good Luck |
Bronze Member Username: Apresler07Canal Winchester, Ohio USA Post Number: 32 Registered: Jun-06 | $400 is more then my whole system. i dont need a really expensive sub i just need something that will keep up with what i have now. |
Gold Member Username: Matt12490Benicia, California USA Post Number: 1152 Registered: May-05 | What is the Athena AS-P4000 tuned to? |
Bronze Member Username: Eib_nationOhio EIB Nation Post Number: 27 Registered: Jul-06 | You shouldnt expect much performance from a little $100 sub. Any spec they list is probably exaggerated. |
Gold Member Username: Project6Post Number: 8731 Registered: Dec-03 | Matt, they seldom specify the port or box tuning for home subwoofers. They do that for car audio subwoofers boxes. |
Bronze Member Username: Apresler07Canal Winchester, Ohio USA Post Number: 35 Registered: Jun-06 | Which enclosure is best for home theatre |
Gold Member Username: Project6Post Number: 8736 Registered: Dec-03 | Alex, whatever it is that you've learned in Car Audio is different for Home Audio. Enclosures have its own set of advantages and disadvantages. You ultimately have to decide which type sound sbest for you and the room you are using it in. |
