Dual CS 503-1 running fast
Username: G11
Just bought a Dual CS 503-1 turntable from ebay. Works fine, but tending to run slightly fast. Had a look at, and cleaned, the belt and any bits it runs round to no avail. My simple mind tells me that a worn belt would tend to run slow. Any suggestions as to how I might fix this problem would be much appreciated.
Username: Nuck
Post Number: 3246
AS, did you check input voltage and ground?
Check neutral to ground to be 0.0v as well.
Username: G11
Thanks for the reply. You've lost me I'm afraid!
Username: Plato
Woodbury, NJ
Post Number: 45
If it runs fast then it doesn't work fine. I would return it, unless shipping is more that its price.
Username: G11
Yes I could return it, but the cost wasn't much more than the shipping, and I'd rather not just give up on what was a pretty good bargain otherwise. I was hoping that someone might know of some way of manually adjusting the speed this thing runs at.
