Bronze Member Username: HannjeffHalifax, Nova Scotia Canada Post Number: 53 Registered: Jun-06 | How do I know if my reciever can use banana plugs? The connections are like a barrol with a hole in the center, right now I unscrew teh cap, slide the speaker cable in a hole and tighten the cap, but, is the hole in the center of the barrol for banana plugs? |
Gold Member Username: Frank_abelaBerkshire UK Post Number: 1488 Registered: Sep-04 | Usually yes. If you let us know what model receiver it is, we should be able to confirm... Regards, Frank. |
Bronze Member Username: HannjeffHalifax, Nova Scotia Canada Post Number: 56 Registered: Jun-06 | Its a sony, and its about 3 or 4 years old. I dont know the model number off hand though (im at work). Is that any help? |
Gold Member Username: Frank_abelaBerkshire UK Post Number: 1494 Registered: Sep-04 | Errr...not me. Again, usually I'd say it's more than likely to be 4mm banana sockets, but there are some screw-only type connections which look like banana sockets around. With the model, we'd probably be able to find out. Regards, Frank. |
Bronze Member Username: HannjeffHalifax, Nova Scotia Canada Post Number: 58 Registered: Jun-06 | Ill have the model later tonight. Same bat tiem, Same bat channel |
Bronze Member Username: MusicluvrPost Number: 70 Registered: Apr-05 | Jeffrey, Check this link for some pictures that should be helpful. https://www.ecoustics.com/electronics/forum/home-audio/180592.html#POST534327 |
Bronze Member Username: HannjeffHalifax, Nova Scotia Canada Post Number: 61 Registered: Jun-06 | looks like mine, great. Thanks guys. Ill let you know if it worked out or not. |
