Hi I came across this amp for $600 I was going to try nad. but I have no way to listen to this amp. But there is a return policy on it if I dont like it, I was just wondering if this was one of NADs better amps and If it would be worth the money? thanks for any comments.
Hey, wroung forum. Most will tell you the NAD sounds great but is not the best built. I have listned to the NAD T753 and in that short time seemed like a good unit. I asked my dealer about this quality issue. He said there were two units with a cold solder issue, and those models have been replace long time ago. Can you buy anything in your local?
