Systemdek and Revolver Turntables
Username: Rockett
Santee, CA United States
Post Number: 7
Systemdek and Revolver turntables.
I have had opportunity to purchase very clean versions of both well regarded turntable brands for a very low cost (around $100 ea). I know very little about the brands. These turntables seem to take a minimalist view as far as engineering that I like. I have also heard that both brands are regarded to build quality decks and are also well regarded for sonic performance.
The hitch is that both models are European voltage & 50Hz (no 220/110 switch). Does anyone know if the motoers can be easil rewired? If not a new motoer would be required. Does anyone know of a source for the new motors and have a rough guess as to how much they would cost?
Username: Nuck
Post Number: 3118
http://www.ab.com/drives/powerflex/4/index.html
Converts voltage, frequency, current.
Username: Frank_abela
Berkshire UK
Post Number: 1467
If anything goes wrong with your Revolver you won't be able to fix it. As for Systemdek, I'm not sure...
Regards,
Frank.
