Turntable not working
Username: Petrpuck
I pulled my turntable out of the basement last night. Haven't used it in 15-20 years. It is a Audio Reflex # 110. I plugged it in, lifted the needle arm but nothing happened. I thought it would start to turn but no luck. What could be the problem ? TIA
Username: Petrpuck
I just figured it out. The belt was fused to thr disc the record sits on. DOH
Username: Petrpuck
Ok.......I got a new belt ..........works great, now I notice the stylus is broken.It is an Audio-technica, AT11E. Since I am just playing around do I have to spend a lot of money or can I buy a cheapy aftermarket styli somewhere ? TIA
Username: Nuck
Post Number: 3122
PP, I got a cheapie AT stylus from a dealers bin and yes it worked, but my old Dual wouldn't tune in very well. It might have been the stylus and setup that thwarted me.
Maybe play around and get your tuning skills/angle/etc straight, then try a better one?
Username: Daniel_badon
Bc Canada
Post Number: 15
peter puck, at least buy elliptical(.3x.7 is better than .4x7). it has better contact with the groove and friendlier to you records.
dan
