chris |
Posted on If you purchase bi-wiring cable fom an a/v store or on line, is one end of the cables 2males with the other end 4males? |
meek |
Posted on are you referring to rca y-cables? then itd be one male and two female connectors. |
Derek |
Posted on Both ends should be male, whether they are banana plugs or lugs. One pair will be at the amp side and two pair at the speaker side. |
