The weakest link kef q15 or nad l40?
Username: Eieiei0101x
Post Number: 89
I have a low cost combo in my office. Nas L40 and Kef Q15.
What is the weakest link?
What would you upgrade to get the most out of the other piece?
Why?
Thanks
Post Number: 90
Any comments
Thanks
Username: Stefanom
Silver Spring, MD United States
Post Number: 80
What are you looking to upgrade? Both are fine pieces of equipment. Certainly you could get better performance with a superior integrated amplifier + seperate cd player, but it depends on how much its worth to you. By the same token, you would get better performance if you upgraded the speakers as well. Which would net you more performance? Depends on what youre looking for.
Post Number: 91
I would like to optimize the system with the minimum investment
Is the amp or the speakers i have well balanced or is any of the components significantly better than the other one?
Thanks a lot
Username: Stefanom
Post Number: 82
Depends on how much of a minimum investment youre talking about, and what kind of return on investment you want to see. Even then, I can't make promises that you would see a serious improvement. As it stands, you've got what amounts to a respectable system.
Username: Nuck
Post Number: 3010
A home office, I suppose, eduardo.
Post Number: 92
Nope office office. About 15 x 15 ft
I got the feeling the L40 could do better with better speakers. I feel like the amp is a bit better than the speakers. But just a feeling with no basis
Would like to improve bass presence. Is it possible with better speakers and L40?
L40. Is 20 watts and 8 ohm capable only
Username: Stefanom
Post Number: 83
If you want bass capability in a small package, the Alegria Audio Emmas will give bass, and excellent sound quality all around. But it depends on how much you want to spend.
Post Number: 94
300 to 500. 8 ohms?
Any other?
Username: Nuck
Post Number: 3012
Algria Audio Ling's. Great range, low volume HQ. Good for office. Low sensitivity, 86db.
Post Number: 95
Price and freq reponse emmas and alegria?
Post Number: 96
Emmas and lings?
Username: Nuck
Post Number: 3016
Emmas are deeeep in the bass, and really love higher power.
Ling's are in 2 flavours, both very well balanced, fabulous vocals, and lower key with a small power source, like yours.
Perfect for not bothering other office workers!
Post Number: 97
Where can i read reviews specs and prices?
Username: Nuck
Post Number: 3017
http://www.positive-feedback.com/Issue20/alegrialing.htm
start here, eduardo.
Enjoy.
I have older series Ling single drivers, and can power them with a 10w T-amp, (close listening) or 40w Rotel.(out of 100).
Post Number: 98
I get a decent bass with Q15s at 1/4 of volume from L40 but that is too high for office. I usually use 10 to 15 percent only
Post Number: 99
After reading both specs i have the concern of lings freq response at 60 hz. Would the emmas work with the L40 at low volume?
Username: Stefanom
Post Number: 84
Yes.
Username: Edster922
Post Number: 4221
eduardo,
What I'd try is adding an external crossover and a small powered sub. The reason your Q15s (which I've never heard myself so not sure how they compare to other speakers) are struggling to put out decent bass is partially because the NAD is only putting out 20wpc at 8 ohms (granted they are honest NAD 20wpc) plus they are small bookshelves so they are not really designed for bass.
So this is what I'd suggest instead:
http://www.hsustore.com/high-pass.html
or, a much cheaper option:
http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=266-272
plus
http://www.hsustore.com/stf1.html
Or, if you want to keep your costs down, you could consider this Mirage 8" sub:
http://www.vanns.com/shop/servlet/item/features/549999992
Your speakers will sound much cleaner in the mids and highs, and you can adjust the powered sub to crank out as much bass as you want.
Username: Edster922
Post Number: 4222
I've heard both the Emmas and the Lings and liked both for different reasons; yes, both have phenomenal bass for their size but 20wpc is 20wpc, I'd be a little concerned especially with the Lings (which have a much narrower appeal than the Emmas, incidentally).
Post Number: 101
Narrower appeal?
Username: Nuck
Post Number: 3022
They are not for everybody. The Lings will appeal to a more discerning ear.
Username: Edster922
Post Number: 4224
The Lings will also appeal more to someone listening at moderate volumes in a moderately sized room to simple compositions that do not have a dense array of different simultaneous instruments/voices --- for example, a piano sonata rather than a full-blown symphony. They do marvelous things with male voices, accoustic guitars, and solo sax. You'll need a good 3 feet between them and your front wall though to avoid boominess, ditto with the Emmas.
Five forum members have reviewed it in fact:
David's review
https://www.ecoustics.com/electronics/forum/home-audio/146884.html
Ed's review
https://www.ecoustics.com/electronics/forum/home-audio/151678.html
Quinn's review
https://www.ecoustics.com/electronics/forum/home-audio/153085.html
Tawaun's review
https://www.ecoustics.com/electronics/forum/home-audio/165396.html
Jan's review
https://www.ecoustics.com/electronics/products/reviews/156699.html
