Username: Hgihkcin Post Number: 10 Registered: Sep-05
Saturday, June 10, 2006 - 22:37 GMT what is the easiest way to undent dustcaps, i have 2 6.5 inch woffers that have dents and 2 2" tweeters that have them also
Username: Jan_b_vigne Dallas,
TX
Post Number: 8679 Registered: May-04
Sunday, June 11, 2006 - 00:35 GMT Try double stick tape. If that doesn't work, take a very sharp sewing needle to the dust caps.
Username: Bvan Cape Town, Copenhagen,...
Post Number: 244 Registered: Jun-05
Sunday, June 11, 2006 - 15:45 GMT i've tried putting my mouth over the tweeters and sucking out the dents. it worked.
Username: Artk Albany,
Oregon
Post Number: 3379 Registered: Feb-05
Sunday, June 11, 2006 - 16:03 GMT You know it worked because he admitted it...lol! Good suggestion Bvan. Hope your transition is going well.
Username: Nuck Post Number: 2966 Registered: Dec-04
Sunday, June 11, 2006 - 17:41 GMT The vacuumn cleaner pulls dents out of dust caps. Bvan's idea might best be performed when the significant other is not around to ROFL while performing.Just a thought.
