Thorens TD 316 pulley wheel
Username: Jimmies
Ok, this problem is similar to some others on this forum - the turntable won't get up to speed (or, at least, it won't stay at the right speed when the stylus is placed on the record). I think the problem is a loose pulley wheel, but I do not know how to fix this. How do I remove the pulley from the motor spindle so I can reattach it with adhesive? It doesn't just come straight off, and I don't want to mess around blindly and possibly break something. If anyone has any help on this, that would be great!
