Reciever shutting self off
Username: Nathan2239
i have recently moved and i set up my system and it worked fine. after a couple of hours i went in to listen to some music. i turned it on and after 2 seconds it shut itself off i have a kenwood KR-V6060 i know it is a little dated but it still works great. i have checked crossed wires and even un hooked all the wires and checked the internal fuse but it still shuts off. is there n e thing else to check or any way for me to fix it. thanx for the help in advance.
Username: Chitown
Post Number: 1080
Sounds like it has gone into protection mode. If you unplug everything and then plug in just the power and it still does this, then you may have to take it in to get it checked out.
