New member Username: StevekaPost Number: 5 Registered: May-06 | Anyone have any experience with either the Niles or Rockustics outdoor speakers that looks like rocks? |
Bronze Member Username: PabloPost Number: 22 Registered: Mar-06 | Hi I am looking for some basic outdor speekers as well. Yamaha NSAW1 at costco $100 canadian looks like a decent option. Pablo |
Silver Member Username: Daniel_canadaCanada Post Number: 127 Registered: May-06 | Bleh. I picked up a set of Omage rock speakers this spring ($250), and they sound great. In fact, they rock.![]() |
Bronze Member Username: PabloPost Number: 23 Registered: Mar-06 | Type 2 Way Acoustic Suspension Woofer 13 cm (5 1/8") Glass filled cloth cone Tweeter 1.3 cm (1/2") Pure Titanium Frequency Response 50Hz-22kHz (85dB) Impedance 6 Ohms Nominal Input 60 watts Maximum Input 120 watts Sensitivity (dB/2.83V,1m) 91 dB http://www.yamaha.ca/av/speakers/Add_ons/NSAW1.jsp They are not that bad! futureshop every 2 weeks has NSAW150B for the same price on sale (now $150). Not sure which set is better. I am about to buy NSAW1 at COSTCO for my backyard and connect with monster outdor cable to my NAD that is in living room. I have townhouse so these are sufficient, If you have single house and looking for real blast then maybe a pair of AW100 by definite technology. Pablo |
Bronze Member Username: PabloPost Number: 24 Registered: Mar-06 | I ended up buying OMAGE GR 305. I am looking as well for outdoor volume control. I was told in store that one that OMAGE does is loosing lots of power and there are better on the market. I ordered one for $120 forgot the name. Any comments on volume controls? |
