HEllo, can someone help me deciding between a hk 340 and a denon 2106? which one is the best choice?...Y will be using the reciver with klipsch cinema 8 speakers
all the above are not what i would recommend for the money spent, so just choose what you think sound better.. any opinions you get on this matter aren't going to help you decide for yourself which is the best choice.
