New member Username: PbigatelPost Number: 1 Registered: May-06 | Ok..so this question has likely been asked, but I have $500 or under spend on a HT receiver. I am yet to buy speakers, but am hooking up system in my new Panny 42" Plasma with HDMI. Looking for opinions on best receiver to buy. Mid-Small room. Any other info needed from me? I am a newbie to this, so jsut looking for idseas and opinions. Thanks. |
New member Username: PbigatelPost Number: 2 Registered: May-06 | ohhh...ideas on speakers for another $500-$800 would be appreciated as well. Or...maybe what I can get Speakers+Receiver for under $1k??? Thanks everyone, much appreciated. This is my first setup over a $250 packaged crap system. |
Bronze Member Username: SackohammersPost Number: 48 Registered: May-06 | I am a total newb myself. But from what I've been reading so far, you may want to adjust your receiver to speaker ratio if your budget is $1k. I love my new Harmon Kardon 635 that I got for around $500. But you may be better off getting a less expensive receiver and allowing yourself more money for speakers. I am sure someone with more expertise will chime in and give more detailed advice. |
Gold Member Username: Edster922Abubala, Ababala The Occupation Post Number: 4088 Registered: Mar-05 | here you go Patrick: Receiver, $350 http://www.accessories4less.com/cgi-bin/item/MARSR5400 5 speakers, $380 http://www.audioadvisor.com/store/productdetail.asp?sku=ATHASB1%2E2&product_name =Audition%20B1%2E2%20Speakers%20-%20Black,%20Pair http://www.audioadvisor.com/store/productdetail.asp?sku=ATHASC1%2E2&product_name =Audition%20C1%2E2%20Center%20Channel%20-%20Black subwoofer, $400 shipped http://www.vanns.com/shop/servlet/item/features/549499051?v_c=Froogle |
Gold Member Username: Suleman36Maryland U.S.A. Post Number: 3847 Registered: Feb-05 | Patrick, That is a sweet suggestion Ed just gave you. Ed def recommends great stuff for great prices if your on a budget. |
Bronze Member Username: SackohammersPost Number: 49 Registered: May-06 | No doubt, that looks really good. Ed is quite the shopper. |
Gold Member Username: Edster922Abubala, Ababala The Occupation Post Number: 4095 Registered: Mar-05 | credit the wife, she has my credit card under lock and key. : P |
