Question about ohms
Username: Cpjet64
ok so my last system just burned out for some reason it was a cyber acoustics 2.1 system and the sub fried so i bought a new Apline type E 10" and i wired it all up. i want to keep my subwoofer but i cannot find any recievers that are 4 ohms. can i use a 8 ohm reciever? and a 4 ohm subplate amp?
Username: Kano
BC Canada
Post Number: 994
If you use a plate amp to power the sub, whether or not the receiver can handle a 4 Ohm load is irrelevant.
Are the cyber acoustics speakers 4 Ohms?
Username: Cpjet64
im not sure what they are. i think they are 4. is there any way for me to test them? but yes it does rnu off of a plate amp i will include pictures of the setup. and also the speakers use a RCA connection so i would have to get a adapter or something i am not sure.
