Monitor Audio B2 V B&W DM602 S3
Username: Crazyhorse
Post Number: 30
Would the B&W speakers be considered an upgrade on the B2's as i am thinking of getting the B&W DM602 S3's to replace my MA. I arent sure if this is enough of an "upgrade" to go with my NAD gear.
What do you think?
Username: My_rantz
Australia
Post Number: 581
I can't comment on your B2's so I probably shouldn't be responding. However FWIW,I have the 602S3's matched with a C162/C272 combo and they sound just marvellous. I found they are better with the NAD gear than with my Marantz SR7300, although reasonably efficient, the 602's seem to like a bit of power behind them. What NAD amp do you have?
Post Number: 31
its the NAD T743, but alas i have gone for the B&W CM2, so I have hopefully gone for the right choice, but they havent come yet. Does anyone have an opinion on the CM2's
