Bronze Member Username: OstPost Number: 12 Registered: Apr-06 | They each use the Seas aluminum cone woofers( Ascends SE) and mids along with the Vifa ring dome tweeter (Onix). Any thoughts about these speakers? |
Bronze Member Username: QuinnPost Number: 100 Registered: Aug-05 | The Ascend SEs use a SEAS double chambered tweeter. The drivers are polygel and I don't think they are from SEAS. THe F-1 should definately be worth listening to. |
Gold Member Username: Jan_b_vigneDallas, TX Post Number: 8539 Registered: May-04 | Give a chimpanzee a pair of SEAS drivers and see what type of speaker you get in return. (No offense to anyone with chimps in their family tree. And, yes, I know the theory of putting a thousand chimpanzees in a room with a thousand SEAS drivers. You'll still get some that throw feces at one another.) It does take more than the drivers alone to make a good speaker. What else do you know about these clunkers? |
Bronze Member Username: OstPost Number: 13 Registered: Apr-06 | http://www.audioreview.com/mfr/tyler-acoustics/floorstanding-speakers/PRD_124345 _1594crx.aspx Sounds nice, but its all about higher model. |
Gold Member Username: Jan_b_vigneDallas, TX Post Number: 8544 Registered: May-04 | You have, in that link, fifty reviews of something other than the speaker you inquired about. I don't know what I could add to that assemblage. There are more than a few very good speaker lines available over the web and this appears to be in the "good" category. If they interest you, I would give them a try. |
