Bi-amping....
patrick gilley
im thinking of getting the elite vsx45tx which i think can bi-amp. do you need to get special speakers that support biamping? if so are there any suggestions. i was originally thinkin of going il60's in the front.
yes, i am personally bi amping with the vsx-ax10
amp and using the yamaha hx series speakers.this
is a great combination,mind you patrick it is at a
great cost also.i'm sure you will find your answer
on the internet or in specialty stores.remember
take your time and do it right the first time.
regards al brimble.
