IPod problem. Please help me...
Username: Mhrprint
i upgraded my macromedia flash player hoping it would finally play music on myspace -_-
well it turns out my ipod isnt compatible with it since it keeps showing a sad face on my ipod. but, if i upgrade my itunes, will it help?. but im afraid that it will erase all of my music. what do i do?!
or is there anyway to take macromedia flash player
Username: Mhrprint
"is there anyway to take macromedia flash player"
what i meant to say was:
"is there anyway to take out macromedia flash player 8? because i had flash player 7 and itunes 5.0. but now that i have flash player 8, it makes sense to upgrade to itunes 6.0, right?"
Username: Project6
Post Number: 8106
A sad face on your iPod means that it needs to be serviced due a hard drive failure. Removing any programs from the iPod is not going to be possible at all. Can your PC still recognize your iPod when you plug it in?
Username: Mhrprint
nope.
Username: Ipodrookie
I have the same problem only mine shows a folder with a "!"
I cant restore it because it doesnt recognize it...
PLZ help!!!!!
~IPODROOKIE~
Username: Mitchgilbert
how can i support all my itunes in my ipod nano coz i don't have a computer what software should i use please help!
