i have a sanyo tv that has developed a humming or buzzing sound, the remote does not work unless you are less than 3 ft from tv. the picture is still good. what might be the problem and is it worth repairing?
You might have some sort of interference, or something screwed up in it(the obivous). If it's worth a repair is up to you, whether you think it might screw up again or no, and you can probably buy a new remote. If you are going to buy a new t.v and are concerned with quality get a SONY! SONY=great quality and durability...you won't regret it trust me.
