Bronze Member Username: AspisPost Number: 11 Registered: Apr-06 | I just got my Paradigm Cinema 110 CT HT system and I need help on choosing a receiver. I was thinking about the Denon 2807. What do you guys suggest I should get? How does the Marantz sounds with the Paradigm? Thanks |
Gold Member Username: Edster922Abubala, Ababala The Occupation Post Number: 4002 Registered: Mar-05 | The Marantz would be a very good choice. |
Bronze Member Username: DarthThe woodlands Post Number: 54 Registered: Aug-05 | no, no, no. Get this one http://www.hometheaterstore.com/store/product.php?productid=1307&cat=0&page=1 |
Bronze Member Username: AspisPost Number: 12 Registered: Apr-06 | What about the Harman Kardon receivers? Are they suited well with the Paradigm speakers? Thanks |
Gold Member Username: Edster922Abubala, Ababala The Occupation Post Number: 4005 Registered: Mar-05 | Yes, HK should also be a fine choice. |
