Home Theatre Sound System Question!
Username: Anthonyarchie23
Yo guys i am new to this HD, surround sound era. I got my Sony WEGA CRT HDTV and my logitech x-530 sound system. Pretty budget system but great nonetheless. However, I wanted to ask all u experts are there anyways to have my x-530 speakers hooked up to my TV, DVD player, and xbox at the same time or simultaneously?..is there another periperal i must buy?....one other thing, is there something i can buy to lengthen the cable length of the x-530 cables? there obviously pretty short........thx alot guys
Username: Edster922
Post Number: 3988
If your Sony has an audio output jack, you'd connect that to your x530, while the DVD and xBox would be connected to the Sony directly.
Check eBay for extension RCA cables if that's what your x530 uses, should be fairly cheap.
