New member Username: LeakiestwinkUK Post Number: 1 Registered: May-06 | Hi - have a Denon DM30S system, that has a DVD player connected, but I also want to connect a Bush MTT1 turntable, so I can record some vinyl. Unfortunately there doesn't appear to be anywhere to put the jacks into. Is there something I can buy that can allow me to do this. I've had a quick scoot around the internet, but nothing makes sense. Please help with words of one syllable as I'm a bit girly when it comes to electronics |
Gold Member Username: Jan_b_vigneDallas, TX Post Number: 8429 Registered: May-04 | Does it have an "AUX" plug ? |
Silver Member Username: Usa2k4Post Number: 145 Registered: Dec-04 | Search for phono preamp such as those on this page: http://www.phonopreamps.com/ They let you connect your turntable to the Denon via either Tape In or Aux In. Some cost as low as $25 US and some cost well over $100 depending on the qual and features they have. |
New member Username: LeakiestwinkUK Post Number: 2 Registered: May-06 | Thank you Kevin and Jan - you are so cheeky, I actually can go up further than one syllable!! Anyway, my husband has just come home and apparently he has some gizmo that has done the job. Thanks again |
