Spare Single Floorstanding Speaker
Username: Trazom
In addition to the following speakers (Front 2x M35, Centre 1xM3c2, Rear 2xM31i) I have a single Mission M35 Floorstanding speaker. Is it of any use in a HT setup or a waste (I dont think I can get a match as they are out of make)?
I dont yet have a sub.
I dont yet have a receiver so not yet locked into a configuration.
Any thoughts?
Username: Usa2k4
Post Number: 140
You can use it in a 6.1 setup as a back surround speaker (if you have room for it :-)).
Username: Trazom
Thanks Kevin. I guess it is a massive overkill? Does it upset balance if your two other rears are smaller bookshelfs?
Username: Usa2k4
Post Number: 141
All HT receivers let you adjust the loudness of each speaker.
Username: Nuck
Post Number: 2464
Send it to a charity, and reap the rewards.
Username: Trazom
Post Number: 8
Hi Kevin, thanks for the help. Nuck thanks for the comment
