Bronze Member Username: PabloPost Number: 20 Registered: Mar-06 | I am looking for a help in choosing outdoor speakers. I have 23' x 20' deck as my whole townhouse backyard, with hot tub in it. In my living room I have NAD 743 with Totem Arro, so I want to connect some outdoor speakers to "B" speakers connection. Futureshop has Yamaha All Weather Speakers (NSAW150W) for $115 canadian (total with tax). I was offered Definitive Technology AW 100 at local store for $380 canadian (total with tax and maybe some outdoor monster cable included as well). I am assuming AW 100 are much better speakers but are they 3 times better as the price? I have neighbors all around so I can not listen loud so power is not an issue. Thanks Pablo |
Silver Member Username: ChitownPost Number: 983 Registered: Apr-05 | My personal opinions is the Def Tech's are overpriced. Also for going outdoors where you have very little control of ambient sound, it does not make a lot of sense to spend money to get better quality sound that get's washed out anyways. Monster cables are another waste of good money. |
Gold Member Username: NuckPost Number: 2429 Registered: Dec-04 | A JVC x200 boombox is a great option that I went for. Lots of power, lots of bass, you can point it away from neighbors and take it back inside. No more than Def Tech speakers, and a whole lotta fun to boot! |
Gold Member Username: GavincummNew York USA Post Number: 1094 Registered: Feb-05 | Iake a look at the Onix outdoor speakers from www.av123.com they aren't terribly expensive, and are said to sound great. |
Bronze Member Username: PabloPost Number: 21 Registered: Mar-06 | Thanks Nuck but I have 200 cd changer, plus 40gb of mp3 on my laptop that I can connect to the NAD so outdoor speakers are the sollution. the question is are AW 100 3 times better then NSAW150W? Pablo |
