Klipsch ProMedia 2.1 THX Issue
Username: Magichat
Okay, I have the klipsch ProMedia 2.1 THX speakers for my computer. I have had to re-solder the rear connector about three times and I finally did it wrong. I found the exact same connector and re did it all with a buch of electrical tape. It sounds great but where is the subwoofer? It does not exist anymore. So I re-did the connection; same thing. Did I short out something? Any help is greatly appreciated.
Mike
Username: Nuck
Post Number: 2417
Solder?
Tape?
TheRed Green thread is somewhere over in computers, Mike.
Username: Petergalbraith
Rimouski, Quebec Canada
Post Number: 1509
Try the Klipsch forum over at http://forums.klipsch.com/forums/14/ShowForum.aspx
Username: Gamerdude
Ontario Canada
Post Number: 35
i'm thinking about getting them my altecs are desent but i want something with a little more punch adn i dont care for logtech i have read alot of bad reviews thow about promedias
Username: Gavincumm
New York USA
Post Number: 1092
bad reviews as in how?
I love the promedias, and own the iGroove. not one problem.
Username: Touche6784
Post Number: 1026
you sure you know what you are talking about kyle? klipsch is a very reputable speaker company, and i have owned a set of their speakers. they were excellent. maybe we are getting the wrong idea from you lack of punctuation and bad grammar.
Username: Gamerdude
Ontario Canada
Post Number: 38
I no that christopher but i mean as in amp dieing adn speakers cutting out,some one told to me to bust them in over a couple of weeks like first week quater volume,2nd week half volume,3rd week 3/4 you get the idea i wasnt saying they were crap i was just saying i have a mixed idea if i should gte them or not
Username: Gamerdude
Ontario Canada
Post Number: 40
Dont get me wrong i like them i just dont no if they would hold up and my dad has one of there subs and it kicks
So Gavin tehy really are great speakers?
Username: Gavincumm
New York USA
Post Number: 1112
yes they are...
I have used klipsch in my home stereo (have since upgraded) and have the promedias as well as an iGroove.
Username: Gamerdude
Ontario Canada
Post Number: 41
I hav e an ipod was thinking about JBL new one 60watts and the sub woofer have close to an inch of travel
http://jbl.com/home/products/product_detail.aspx?prod=JBLRADIALWHT&Language=ENG& Country=US&Region=USA&cat=HMM&ser=HMM
you have inspired me to get the promedias as soon an i can get them :D
Username: Gavincumm
New York USA
Post Number: 1113
there is no way a driver that small can have that much travel without a ton of distortion IMHO, unless they are the really high end drivers seen in stuff like MartinLogan, Krell, McIntosh designs, not JBL Ipod speakers.
glad I could be some inspiration.
If you are in the market for some ipod speakers, strongly consider a refurb igroove from klipsch. they run only $150 and sound fantastic!
Username: Nuck
Post Number: 2500
Gavin, you might want to add Alegria to that list.
4" full range drivers in the Ling.
Nice.
Username: Gamerdude
Ontario Canada
Post Number: 42
refurb....hmmm you bought a refurb one Gavin?
allmost an inch of travel sounds like it would over drive it self
whats IMHO??
i like that center
http://www.us.martinlogan.com/display_speaker/cinema_i.html
Username: Gavincumm
New York USA
Post Number: 1121
I myself used to have the MartinLogan Scenarios, and am now looking at buying a pair of the Claritys.
yeah, the cinema is their cheapest electrostatic center, at $2,000 a pop
