New member Username: MarkpopeLawrenceville, GA USA Post Number: 6 Registered: Apr-06 | Gentlemen and the occasional lady! Many of you, the erudite and all knowing audiophiles, attempted to steer me toward the nirvana of speaker arrays < $2,000 (5.1 system, etc. see earlier "Guru's needed..." post). I was leaning toward Monitor Audio but couldn't find prices that worked. Based on preponderance of evidence semi-convinced of Paradigm. However, my earlier analysis neglected the spousal approval factor and I met with resistance as I'd promised my new speakers would be smaller than my old speakers. Now I'm looking at space savings designs and want to know the trade off with speakers such as Paradigm's Cinema 330 speakers? (I listened w/a sub and felt reasonably impressed.) Am I better off w/bookshelf square types? (They ain't real purty as we say down south.) Is there a better speaker that's wall mountable and still in the price range ($300 each for front L & R as well as center, $109 each Cinema ADP side, and thinking HSU STU-2 sub)? What might be a better system? Also, gently, slowly, & finally moving into the receiver spectrum. Unless someone sways me from the above Paradigm based, based on past posts I'm considering the NAD T763 (used around $1,000) or the Denon 3805 (3896 is out, better? 2807 should be out, what up? 4306 out, expensive but I might have a line into getting Denon at true wholesale). Suggestions? |
New member Username: MarkpopeLawrenceville, GA USA Post Number: 7 Registered: Apr-06 | Forgot to add dealer pushing a Marantz SR5600 w/Paragigm speakers listed (dealer thinks I'm still on the line for the Paradigm sub but based on threads read here picked HSU STU-2). Asking $600 but threads iffy on Marantz/Paradigm mix. Thoughts? |
New member Username: MarkpopeLawrenceville, GA USA Post Number: 8 Registered: Apr-06 | Okay, last thought. Looked for HSU STU-2 obtained through ecoustics threads reviews, couldn't find. HSU's sight lists HSU VTF-2 MK2. Same price as dealer quote for Paradigm PDR12 but is a 10'. What up? What best? What do? |
Gold Member Username: PetergalbraithRimouski, Quebec Canada Post Number: 1504 Registered: Feb-04 | You are thinking of a STF-2: http://www.hsustore.com/stf2.html I have an STF-3 and had borrowed my mother's PDR-10 for a week before I got the STF-3. There is no comparison whatsoever, so I'd believe thatthe STF-2 is also a better buy than the PDR-10. |
Bronze Member Username: JethroLansing, Mi Post Number: 76 Registered: Jan-06 | denon is good if u get a good price on it for a receiver. however, for similar price range w/o discounts etc, u should check out harman kardon and pioneer elite. i auditioned the pio elite vs similar priced denon (3806 vs ts74) and the pio elite won hands down in stereo. in ht, u be the judge as i found no discernable advantage btw the 2. i have a hk avr525 which i think is a rock, and sounds great w/ my b&w setup, but i like my denon 3805 better with the b&w speakers i use for mostly HT. so to give u direction instead of more choices, i would say pioneer elite over denon and hk, also audition marantz w/ the paradigms. check out pio elite 72. but best of all, and cliche, listen to em all w/ paradigms;; u decide as for HT all will probably yield u a perfectly acceptable killer sound with dvds. i'd say listen to your top 3 for music only, and pick the best sounding and purchase it, u cannot go wrong in this range imo. |
Bronze Member Username: JethroLansing, Mi Post Number: 77 Registered: Jan-06 | hey peter i read ur posts and just thought it was "special" that u borrowed ur moms paradigm sub for a tryout ![]() jeff |
Gold Member Username: ArtkAlbany, Oregon USA Post Number: 3221 Registered: Feb-05 | "iffy on Marantz/Paradigm mix. Thoughts?" Marantz and Paradigm go together very well I've owned 2 such HT's and enjoyed them immensely. Just keep the speakers to the Monitor series or below (as you mentioned, the Cinema series) and you'll be fine. Oh and Peter is quite correct the Hsu is a far better sub that the Paradigm PDR stuff. However, the new Paradigm Ultra Cubes are very good. Good luck. |
New member Username: MarkpopeLawrenceville, GA USA Post Number: 9 Registered: Apr-06 | Thanks Peter & Art, will pick up the recommended sub! |
Gold Member Username: PetergalbraithRimouski, Quebec Canada Post Number: 1505 Registered: Feb-04 | :-) Right, and my Mom is in her seventies too. The fact is I was late in the game of HT and only got a Dolby Digital and DTS capable receiver two years ago (the reason I joined the forum), and a sub about 6 months later. I then added a center speaker over a year ago, and upgraded my front main speakers about a year ago. I got a CD player about 6 months ago. I guess I'm due for the next hit! |
Gold Member Username: NuckPost Number: 2400 Registered: Dec-04 | You realize, Peter, that at some point you will end up looking at a nice stereo setup, don't you? |
New member Username: VaritPost Number: 9 Registered: Mar-06 | Have you checked out Orb Audio? The look isn't for everyone, but the sound is superb. Definitely within your budget, too. |
Gold Member Username: PetergalbraithRimouski, Quebec Canada Post Number: 1508 Registered: Feb-04 | Yeah Nuck, at some point. To my ears, I've reached a "nice setup" about a year ago. ;-) |
New member Username: RtlbuilderNYC , NY USA Post Number: 2 Registered: May-06 | wonder if these would pass the SAS ;) http://tpluspod.com/rtl/fostex%20PVChorn.html ![]() |
Gold Member Username: NuckPost Number: 2614 Registered: Dec-04 | how funky is that? |
Silver Member Username: PraetorianCanada Post Number: 194 Registered: Dec-05 | At a grand? Not very... |
Gold Member Username: NuckPost Number: 2628 Registered: Dec-04 | The Marantz and Dynaco's Michael. |
Silver Member Username: PraetorianCanada Post Number: 197 Registered: Dec-05 | Heh... I'll have to take your word for that! Not into the tubes. |
New member Username: DoctorsorderSt. Louis, MO Post Number: 1 Registered: May-06 | hey.. those are really neat speakers anyone hear them? I think I will try to build a pair, anybody figure them out? I can probably make them for less $ |
New member Username: DoctorsorderSt. Louis, MO Post Number: 2 Registered: May-06 | hey.. those are really neat speakers anyone hear them? I think I will try to build a pair, anybody figure them out? I can probably make them for less $ any more info on them? |
Silver Member Username: PraetorianCanada Post Number: 204 Registered: Dec-05 | http://www.t-linespeakers.org/projects/davidduke/index.html |
