Stereo speakers
Username: Ssonntag
I have a Yamaha av-80Y stereo smplifier. I know nothing about hooking up speakers. I have two speakers in the house and tried hooking up two outdoor speakers. Everything is hooked up but I can not play the indoor and outdoor speakers at the same time. What am I doing wrong?
Username: Jan_b_vigne
Dallas, TX
Post Number: 8379
Don't know. How do you have the speakers hooked up?
Username: Grief
As I have mentioned before on another post you can use a b-tech speaker switch taht allows to play both speakers at the same time.Check b-tech 's site for a full range of products.Try the BT-12 at http://www.b-tech-int.com/
