Need a good set of front speakers and maybe a center chanel?
Username: Silas92
Post Number: 62
Hey guys im purchasing some athena micra 6's. the receiver im getting is 7.1 so i need 2 good upfront and maybe a center speaker that will blend in with the athena's sat's and sub?
Username: Project6
Post Number: 7647
Budget? You should know this by now:-)
The only thing that will blend well with Athenas are other Athenas. You have your ASB series and then the ASF series as well. You are not really doing well with your research are you?
Username: Basicaudio
Chula vista, Ca US
Post Number: 70
what matters is that it sounds good to you, whatever it is? You know what matches well with athenas, HYENAS! at least they will smile at you before they bite you! (-:
