My memory.. Yamaha speaker match
Username: Phrapp
Post Number: 13
I bought a Yamaha reciever, works for the time being. I have PSB's running on them right now but as I was told by one of you guys ,"they are bright"
My question is paradigm the best match for a Yamaha??
I have had Polk pimped to me how would they do as a match?
A top three speaker list would be great.
Oh and im either going to get bookshelf or sats.
thanks
Username: Stu_pitt
Irvington, New York USA
Post Number: 1219
PSB's aren't bright, Yamaha receivers are usually bright.
Why are you looking for a change? What are you trying to accomplish? Warmer sound? Brighter sound? More detail? Without knowing what you're looking for, it makes it difficult to accurately give you any direction.
Username: Hawk
Highlands Ranch, CO USA
Post Number: 849
"B"
The issue is not if someone told you your system sounds bright. The real issue is do you think it sounds bright? Personally, I think the Yamaha/PSB combo is a good one because as Stu points out, the Yamahas tend to bright (lower end models under $1500), but the PSB speakers tend to be rather warm and laid back (just like Paradigms), so it is a combo that works rather well, in most cases. Everyone hears differently, a system I might like will not please everyone; conversely, I know of some systems that certain acquaintences have that I don't like at all. But, hey, if it floats their boat, then I say "Great!" The bottom line is that it is your money, so you need to get the system that pleases you and if someone else has a contrary opinion, then my belief is that they can criticize only if they are willing to buy you a new system.
So, to facilitate this discussion, what Yamaha do you have and what PSBs? We can make a more informed suggestions if we know which models you currently have.
Now, if you want bright, you'll get it if you buy Polks for a Yamaha receiver. Polks are fine speakers, but they are much more forward than PSBs, so the brightness of the receiver will literally "shine through." It is not a combo I would generally recommend.
Username: Phrapp
Post Number: 14
Oh sorry,
I think I should give a little more info.
I have a Yamaha 5890 and PSB Image 2b's and a image subsonic 12" sub.
I have no real problem with the sound, it is good but "real clean" sounding if that makes sence?
I had an imfamous NAD that kicked the PSB's into high gear, but the NAD crapped out and so did the service, so I move on to a cheaper brand in Yamaha.
I love the PSB line but hate my local dealer he is a dolt, he took over for the guy I originally bought it them from, and since then if I am not buying new I get no help.
As I understand it too PSB is owned by NAD so they match as a system.
I just wanted to know if any other speakers could give me better if not par sound on my Yamaha compared to PSB.
thanks again
Username: Gamerdude
Kitchener, Ontario Canada
Post Number: 14
This may sound newbesh but whne you say bright you mean good sounding?
Username: Project6
Post Number: 7725
No.
Username: Gavincumm
New York USA
Post Number: 1021
I myself can't judge on this, because the latest combos of yamahas that I have heard have been with paradgms, and they have been VERY smooth. The paradigms are a great match IMHO :-)
man...took me a while to proofread...lol
Username: Gamerdude
Ontario Canada
Post Number: 21
Then what dos it mean? lol
Username: Gavincumm
New York USA
Post Number: 1023
wow...sorry
I wrote that after I had a little to drink lol...
let me translate that...
Paradigms and yamahas are a great match. Older yamahas (especially the CD players) are terribly bright, but the more I am around the recievers, I realise that they have improved.
I would definatly reccomend pairing a yamaha reciever with paradigms, psbs, or other canadian speakers. Honestly, the only speakers within reason that I wouldn't pair with a yamaha is klipsch, axiom, or other speakers of the like that have a similar bright and forward sound.
I was at tweeter this past summer and heard a yamaha intergrated (forgot the number) and I had the rep hook up to a pair of ML clarities for kicks. I was slack jawed.
Username: Stu_pitt
Post Number: 1235
I'm still trying to figure out what the OP is trying to change, sound wise.
