Harman Kardon AVR 5 Receiver power problem
Username: Bobha
Post Number: 27
Hi guys this from Fixya,
http://www.fixya.com/problems-solutions/t103264,p29821/Harman-Kardon-AVR-5-Recei ver.aspx
I'll appriciate any help you cn give me.
Thanks,
after a power jump( like a short "wave" of voltage that's higher then normal) occurred in my house the receiver stoped working and wont turn on at all. when i connect it to a power source it smells like something is burning. I opened it and couldn't see anything that seemed burned. what are the odds i could fix it myself by changing a fuse? do I have to take it to a repair lab?
Username: Nuck
Post Number: 2276
Bob, if you do not own a meter take it to the shop.
Username: Praetorian
Post Number: 149
and don't tell them you opened it if the warranty is still good...
