Bronze Member Username: Silas92Post Number: 49 Registered: Apr-06 | Hey what do u guys think of my setup? its for a small room and used for %50 music, %25 games and %25 movies? |
Silver Member Username: EldTexas Post Number: 158 Registered: Dec-05 | Great. ![]() |
Bronze Member Username: Silas92Post Number: 50 Registered: Apr-06 | lol thanks, do u know were the best place (the cheapest) is to get the athena's? |
Silver Member Username: EldTexas Post Number: 160 Registered: Dec-05 | I would buy them at your local Best Buy. Saves time and the taxes should be about the same as shipping cost. Plus you gain all the benefits of having a local store nearby if there are any problems. Just don't let them talked you into buying any expensive speaker wires, etc. ![]() Lowes or Home Depot 16 gauge wires are fine for the sats. http://www.bestbuy.com/site/olspage.jsp?categoryid=cat03049&id=1077624907950&sku id=6376628&type=product&ref=06&loc=01 Good luck. |
Bronze Member Username: Silas92Post Number: 51 Registered: Apr-06 | what about radioshack 14 gauge wire 50ft for $20 and its flat which is ideal for me, becausse i need to run it under the carpet!!! |
Silver Member Username: EldTexas Post Number: 162 Registered: Dec-05 | That should work, Silas. Remember to keep the runs short as possible. ![]() Happy listening. |
Bronze Member Username: Silas92Post Number: 52 Registered: Apr-06 | Yeh ok thanks alot for the advice. |
Bronze Member Username: Silas92Post Number: 53 Registered: Apr-06 | yeh those Best buy guys tried to fool me into buying a hdmi cable that cost $100, when I bought my tv. Lol i had a look on ebay for hdmi cables and u can pick em up for like $5. |
