Technics 1200 MKII Speed Problem
Username: Mddiron
Jacksonville, Florida US
One of my MKII's suddenly will only play in one very fast speed (faster than 45rpm) independent on speed selected (33 or 45). I disassembled the board containing the Start/Stop (P.C.B. Assembly) and try to get it by part number. I was told by Panasonic that the board was discontinued. Does anyone know which component I'd need to replace and where to get it. I suspect it may be the little power switch (P/N S601-SFDSSS5GL13P). See http://1200s.com/Shop/product_info.php?cPath=1_7_15_18&products_id=169
Thanks in advance.
Username: X99
That power switch is the on/off switch - don't see how that would be your error.
the PCB your after is available on ebay as a LED modification. sear chipsforbrains
