Cerwin Vega PD-9 Spec. Ed.
Username: Wonka001
I've got a set of PD-9 Special Edition, someone's asking me the wattage on them, does anyone know what it might be? I looked all over the cabinets and have not found anything that might tell me. I have pictures of them, but not tonight, anyone with some info, would be nice to know.
Username: Kano
BC Canada
Post Number: 908
DESCRIPTION: 15" 3-Way Loudspeaker
FREQENCY RESPONSE: 25 Hz --20 kHz
POWER HANDLING: 5/405 Watts RMS (Min/Max)
SENSITIVITY: 103 dB (1 Watt @ 1 Meter)
IMPEDANCE: 6 Ohms
LF DRIVER: 15" Die-cast Frame / 2" VC
MF DRIVER: (2) 7" Cone
HF DRIVER: 1" Voice-coil Phenolic Dome Horn
CROSSOVER POINTS: 250/3500 Hz
WEIGHT: 90 lbs.
DIMENSIONS: 36" x 17.5" x 19.25"
Username: Wonka001
Thanks for the info. Where did you go to find it?
Username: Croozer
Rockford, IL United States
Post Number: 49
I have a original pair of D9's and a pair of Re38's, boy I used rock Cerwin Vega back in the day.
Username: Jan_b_vigne
Dallas, TX
Post Number: 8235
Speakers don't have watts.
Username: Eld
Texas
Post Number: 144
Hehe, speakers do have watts, when you feed them some from the amp. Otherwise it can't do work. :-)
The specification says "POWER HANDLING" ability, not power generating ability. :-)
Dallas, TX
Post Number: 8238
Picky, picky, picky.
Dallas, TX
Post Number: 8239
Just to further clarify, only speakers with a voice coil moving within a magnetic gap have any "watts" whatsoever. So not all speakers have watts. Not that it matters to the discussion.
Username: Timn8ter
Seattle, WA USA
Post Number: 874
Crap! I was told my plasma tweeter had 2000 watts!
Username: Eld
Texas
Post Number: 145
Hehe, that is pretty low for a plasma tweeter, Tim. :-)
Username: Timn8ter
Seattle, WA USA
Post Number: 876
It's just a little one but it comes in handy on fondue night.
Username: Eld
Texas
Post Number: 146
Tim,
Sounds like the tweeter have been broken in admirably.
Now I'm hungry (steak and merlot, maybe). :-)
Jan,
Sorry, I wasn't trying to be picky, just trying to clarify so those with less technical background won't misunderstand.
Now it's time to go home and listen to some music. :-)
Dallas, TX
Post Number: 8245
This is a question salespeople get all the time. By the time you explain the energy developed in the voice coil and what happens to it when it leaves the voice coil and how that affects the amplifier, it is much easier to say, "speakers don't have watts".
