Muffled sound right speaker
Username: Antm88
hey, i dont know too much about this, so i jst wondered if anyone had any ideas:
basicly ive got a pair of wharfedale diamond 8.1s connected to a NAD C320BEE amp, and i recently noticed that the right speaker was quite muffled and quieter compared to the left one. its not an enormous problem for me - for now ive changed the balance on the amp; im just wondering if there is a simple solution to it.
the only cause i can think of is the fact that ive linked 2 wires to reach the right speaker, but i wouldnt have thout it would make a huge difference - the connections seem to be fairly solid, and i dont recall having the problem when i first set them up - about a year ago.
any help would be appreciated.
thanks, ant
Username: Project6
Post Number: 7390
Swap the speakers. If you still get muffled sound on the same channel, it's your amp. Otherwise it is a problem with your speakers.
Username: Antm88
hey thanks for replying. ive swapped the speakers around and im getting the muffled sound on the same channel still.
does this mean its the amp?? i hope not :-(
Username: Project6
Post Number: 7414
I think you know the answer to that.
